Inlet Runners for a 3.0L conversion
I'll post the steps I used in building the new inlet runners. It may be useful to others wanting to do the same thing, particularly if you only have home workshop tools and can do a bit of basic welding.
David
David
- 41mm ID exhaust pipe, mandrel bent to keep ID through the bend. Bend is 35 degrees.
- I1.JPG (19.24 KiB) Viewed 9292 times
- Chisel out the remaining bit. Not as hard as it looks as the flanges are brazed to the pipe and comes away quite easily. The bronze is also easy to grind out to take the larger pipe.
- F3.JPG (20.82 KiB) Viewed 9293 times
- Cut the flanges off the original runners. Leave a bit of pipe sticking out to get the chisel behind.
- F1.JPG (10.57 KiB) Viewed 9292 times
More
- Press fit them into the flanges.
- I5.JPG (10.33 KiB) Viewed 9281 times
- I made up a small jig to get the angle right,
- I4.JPG (21.1 KiB) Viewed 9282 times
- Cutting the correct length and angle was the hardest part.
- I3.JPG (16.45 KiB) Viewed 9283 times
Steve,
The best you can get from the 2.5 plenum is 39-40mm, which I still think is enough for a stock 3.0L. The "flange" inside the original 3.0L runners is actually close to the ID of the 2.5 reamed out runners.
I used a good quality USA straight edge "reamer", not sure what they're called but they rip out the alloy quickly. I also used this to ream out the inlet flanges. The attached photo shows the 2.5 plenum and the tool.
David
David
- PL1.JPG (16.41 KiB) Viewed 9229 times
David,good stuff mate! You might want to contact Patrick Centurion in Sydney.He might be keen on a set from you.He`s fitting a 166 motor into his gtv..Will mail you his contact.
Great stuff David!
So the 2.5 plenum has a limit of about 41mm id? Will it limit the flow a lot if mounting 45mm id runners and only using a 41mm plenum opening?
On my 164 3.0QV plenum I´m using the runners are 45mm id and openings in the plenum to match. Should be prutty good then huh?
- The plenum has been modified to work in the GTV6. Cut off a bit and with a 180 bend to go with it...,
- Sebbans plenum kopia1.JPG (71.97 KiB) Viewed 9218 times
156 V6 24v -98
GTV6 3.0QV-83
156 V6 24v -98
GTV6 3.0QV-83
