Yeah,yeah,yeah I know what you meant Z, its just that Croc. Dundee decided to shake some fleas off and woke up, damn !
Re: brembo piston index?
Sorry for digging this one up, but I found out that pistons were fitted quite randomly on my gtv6, the result is uneven pad wear (slanted) and I guess poorer braking performance. Anyway since pistons are in horisontal relation to the disc, then wchich positon is correct? I would guess the lower one, but on 105 cars which have similar system the piston is supposed to be rotated 22 degrees against the rotor. That got me a bit confused
- piston position.jpg (16.06 KiB) Viewed 5928 times
no one?
The angled one is correct.
Tack så mycket.
Varsågod.
Is that Shnitzel talk for ..that circle's got a hole in it?
No wonder your brakes are playing up, ya?
