116 GTV BRERA Race car !!!
So when you want a chain driven Alfa motor(heads) and you increase to 3.8 and you bored put it into the timeless GTV body. The barrel throttles have proved highly succesfull here on SA 's fastest 2.0L Giulietta. Note the small idle screws as it always the hard part to get idle right on individuals.
All this work is at Glenwood motors new workshop at Zwartkops race track .
- breragtv.jpg (35.99 KiB) Viewed 11928 times
- breragtveng2.jpg (37.23 KiB) Viewed 11928 times
- breragtvengine.jpg (39.06 KiB) Viewed 11928 times
- breragtvthrot2.jpg (27.63 KiB) Viewed 11928 times
Re: 116 GTV BRERA Race car !!!
MD if you out there, check my brake master cylinder set up. Took it offf my race car for this project of Dawies as mine was gathering dust.
They're upside down on that second picture... So i'm guessing there is a set of three for the other side as well.
Front mount gearbox? Camaro/Commodore unit should just bolt up?
Thermostat on the rwd GM iterations of that motor is in a most impractical place - anything been done to make that easier?
1966 GTV
1982 Suzuki "Bathurst" Katana
Getrag box in . Is getting closer
- glenbrer3.jpg (121.02 KiB) Viewed 11747 times
- glenbrer2.jpg (64.71 KiB) Viewed 11747 times
- glenbrer1.jpg (61.61 KiB) Viewed 11747 times
This 3.8 brera ''GTV'' is nearly there. its impressive to see a major turn around over the last year into the cosmetics and ''bling'' on the cars leaving this workshop. This motor is a real screamer - watch out Jules , this one screams louder than yours. pic of Div next to his creation.
- glenwood2.jpg (107.01 KiB) Viewed 11615 times
- glenwood1.jpg (90.95 KiB) Viewed 11615 times
- SydneyJules
Mine will scream for a little longer... Then she will just boost her way to wheelspin- got some time off, so she'll be worked on again soon... Saving $$ for the repair and rebuild.
Kev, that donk looks awesome
How will the chain hold up? I've heard quite a few stories of chains needing replacement because they slack rather quick on road cars.
Ten million years if it has the miles/year of any average privately funded race car.
Is this the V6 that is based on the Holden engine that was a product of the GM-Fiat Powertrain alliance?
'84 GTV6 3.0L
'81 X1/9
'81 X1/9
Looks like it.
Yep, its an Australian alfa
