Original GTV 3.0l race car build gearbox upfront (Nelson)
Firstly this is not my car but I did do engine conversion for owner Nelson. PowerMods are fitting gearbox upfront and all suspension,brakes supplied by me.
PowerMods are famous for "his" 155 twin turbo rear mount and new 155tt front mount being built.
The GTV is just gonna be a fun club racer with 15'' rims and later two big turbos bolted on.
Only sad part is it was a beautiful origional GTV 3.0 carbi
- nelsonadaptor.jpg (78.86 KiB) Viewed 10396 times
Re: Original GTV 3.0l race car build gearbox upfront (Nelso
Dont pay attention to stickers on gearbox.
- nelsonboxview.jpg (77.67 KiB) Viewed 10395 times
Hey Jim , your headers I sent should fit and look like the ones above.
Pic of engine in but will come out again to neaten up firewall cutting
- nelsonenginein155.jpg (64.2 KiB) Viewed 10395 times
last pic. Also mention that a tried and tested Gotech will be used as owner of PowerMods is the brains behind the system.
- nelsonunderside.jpg (61.94 KiB) Viewed 10395 times
Looks very good
I'm still interested in the drawing for that adapter plate...
I must send you domingoes email address or search powermods . Every time i want to copy the adaptor he joins it up to another test motor.
Found it and emailed him. Thanks for the pointer.
any pictures of the complete trans tunnel?
Kevin I'm either blind or illiterate, but what kind of gearbox is that (car/manufacturer)?
Its a 5sp getrag from an M3 . I got some more pics of tunnel. Its coming on nicelly as they took a tunnel out an m3 then shaped it to fit the gtv.
Surely you mean a ZF from an M3? E36?
Domingos told me it's an E36 5 speed M3 box. And that's a Zf unit.
Yeah late stuff , its from E 36 zf . Not sure why i wrote getrag and 5 speed. ( to busy watching SA kicky Ozzie ass in cricket , not that i like cricket )
Will he send you an adaptor plate ?
The company that made the plates didn't have the drawings anymore but he was going to get some more adapters made and then he would send me the drawings.
I will try get more pics of them fitting the sei rear section in as i have seen there is an easy way with a certain bracket made to diff. This is pretty tricky so will get pics for you .
