Re: Mats Strandberg (SWE)
Are the studs in the head the only thing supporting the weight of the manifold + turbo? Maybe you should fit a support like on the original 75 Tb?
Those AN fittings are huge . Not much room to fiddle the hose onto the couplings indeed.
Well... umm... yes, I supose that method would work well tooMats wrote:Wow...
I was thinking more on the lines of just measuring hur far down from the splitline between the sump and block the Min mark is and be happy with that.
I was trying to think of a way to do it without having to remove the sump - but that's obviously not a big issue for you at this stage of your build.
Did you have your exhaust flange laser cut and then mill the port angles, or was the whole job done on a mill?
There will be a support, probably from the engine mount to the wastegate bolts or something, haven't really figured it out yet.
Even if I can make the hose there would be no way to fit it, AN fittings are insanely sensitive to any misalignment during assembly and imagine trying to get the second one to catch the threads correctly with the hose even more bent then when in it's final position.
I'm going to have to remove the sump, the oil pump is still in a box on the shelf.
The flange is actually cut on a water jet with some tricky fixtures. A milling machine would have been the obvious choise but no-one seems to want to do it at a price that is reasonable.
Looks pretty good! I'm happy anyway.
Today I might actually make some progress with the engine harness. Or something else that needs to be done before I can start it up. Still thinking about the exhaust routing for instance.
Need o fit a catalytic converter in there somewhere. Yes, you heard me... Racing rules.
- Test fitting
- image.jpg (139.63 KiB) Viewed 5918 times
Getting there ! On the manifold exhaust flange which which bolts to head , are the holes for the studs bigger in centre ie pots 2 and 3 ie 9.5mm compared to outer pots 1 and 4 at 8 mm .
I used to have to do this on my GTV nord turbo or cut slots in the flange between the pots as the heat and expansion used to break studs . But then this was a daily driver not a racer which clocked very high mileage .
Can't believe you have to have cats on . Is that all classes of racing in Sweden
What's the logic on the bolt holes? I could see it for the outer bolt holes being larger but the inner?
All racers except the App-K cars (FIA Historic papers). They don't last long on the tuned carb cars. They are never checked though.
Mats , it does make more sense outer been bigger as movement should be more ( knock on effect) but the heat is more contained in centre that's where you're greatest expansion is .
Sounds nice... but if you heat a long piece of metal it tends to expand from the middle to the ends. So at the ends the holes will be pushed out more compared with the holes in the middle.
My point exactly, but I'm guessing he is talking about a flange that has four separate flanges at h exhaut ports?Giuliettaevo2 wrote:Sounds nice... but if you heat a long piece of metal it tends to expand from the middle to the ends. So at the ends the holes will be pushed out more compared with the holes in the middle.
Anyway, spent the afternoon studying a NACA paper from -56 regarding mufflers. Very interesting.
It's snowing... WTF..?
- Maurizio
luckily we had that a few weeks ago (around easter) hopefully for the last time this spring.Mats wrote:It's snowing... WTF..?
Car freitag, normally the un-official opening of the nordschleife for the big public ... this year http://www.youtube.com/watch?v=zBH1ou-fADE
Snow/cold kind of takes out the motivation and fun to go into the garage... at least I have that
I agree, add darkness to that and you have the explanation why I don't get anything done during the winter...Maurizio wrote:luckily we had that a few weeks ago (around easter) hopefully for the last time this spring.Mats wrote:It's snowing... WTF..?
Some more pics, just showing off...
- Snug fit but it will be ok (famous last words?)
- image.jpg (139.7 KiB) Viewed 5806 times
- Detail view
- image.jpg (157.71 KiB) Viewed 5806 times
- Nice and low profile
- image.jpg (192.64 KiB) Viewed 5806 times
- Plenty of room for the downpipe
- image.jpg (186.49 KiB) Viewed 5806 times
- Overview
- image.jpg (195.21 KiB) Viewed 5806 times
- SydneyJules
Bellissimo
