Father son project
So after many years we have an alfa in our drive way again this time it's a GTV .
For now the plan is to fix a few things and enjoy it.
- needs to be neatened up
- 20130907_174648 copy.jpg (207.42 KiB) Viewed 11201 times
- 20130907_174619 copy.jpg (177.62 KiB) Viewed 11201 times
- need to change to some thing darker
- 20130907_174601 copy.jpg (207.76 KiB) Viewed 11201 times
- 20130907_174540 copy.jpg (198.92 KiB) Viewed 11201 times
- 20130907_111335 copy.jpg (247.82 KiB) Viewed 11201 times
Burn Rubber Not Your Soul
Re: Father son project
Congratulation powermods. Seem to me like a very early version and even not in original color I like it. Is it a conversion from a TS? I also noticed the whole ignition key unit is removed and replaced with a button. So you don't need a key to start it at all?
The ignition key is one of the things I plan on fixing
congrats!!!!!!!!
Great project car . No rust . Out of interest what are the last three digits on your vin number . Is near the 400 figure . Did you see Konrad was selling a 3.0 interior . For those outside SA it was only a handfull of 2.5 that has the recaro pinstripe interior as Alfa Romeo SA kept the old 2.0 style for these cars . Note these cars came standard with aircon .
kevin i will check the vin for you tonight .this car dosnt have air con
Cool . I see the a/c unit is still attached to dash but probably removed in engine bay as you say . The GTV without a/c has a different centre consul .
Looks like its near the end of 1982 or early 1983 .
So rack ends and tie rods were toast on the GTV so today I finally got chance to change them not a bad job thought it would be harder because I was going to be doing it on the garage floor and not the lift at work but wasn't bad at all.
- 20131019_091028.jpg (157.71 KiB) Viewed 10956 times
- 20131019_123340 copy.jpg (200.12 KiB) Viewed 10956 times
- 20131019_091035 copy.jpg (119.61 KiB) Viewed 10956 times
so it been a wile so thought i better post an up date.
well windscreen wipers were not working so started poking around before the holiday season and tried all sorts of things to get them to
work it turned out to be a fuse
Then I decided to change brake pads and gear box oil witch didn't help for the crunch in second gear and gave the chassis a coat of rubberizing.
Then the last thing the clutch master cylinder witch I finally replaced today had been putting it off for a wile my dad and I got started at around 8 and was done by 10:30 and it feels great
to have no clutch shudder no slipping nothing.
So i drive take the GTV to work last week friday and to step out of the work shop for a wile and on the way back I decide to give it the beens next thing there is a huge vibration seems like i have popped a cupling
so now i have the fun job of removing the prop shaft not looking forward to that
