SamW's GoTech
I am on vacation this week, lot's to do, I am in the middle of a head gasket on my GTV6, but I am on hold due to a bad fitting head gasket. So... I played with the GTed Verde today, I did a final mount of the GT unit and DonG and I took it for a spin around the block, runs pretty good, still rich, but runs. I took a few pics, so here they are. I am painting the Benzoni wheels, I have the speedlines on there now, but i have 195/55/15 tires on order.
- Interior mount
- Verde Inter GTsm.jpg (55.65 KiB) Viewed 16568 times
- Engine bay
- Verde Engine Sm.jpg (80.6 KiB) Viewed 16569 times
- Notice the spare parts in the back ground
- Verde sm.jpg (66.84 KiB) Viewed 16569 times
- junglejustice
Funny. That's where I wanted to put mine, except I want it inside the ashtray so that you can't see it with the ashtray closed (smog...), but you can open the ashtray to check the LEDs and play with the potentiometer.
be very carefull in the placement of your gotech ecu's.... I had a client last year who insisted that his gotech ecu must be fitted in the centre console. So we did as told. He took the car and went on vacation to Durban, which is about 800km (500 miles) from our shop. While on vacation his car was broken in to and the stole the Gotech ecu, probably thinking that it was an amp or something. Stranded in Durban he had to buy a new ecu there and fortunattely for him I could email the map down there to be loaded onto the new unit.
Now that I have most other things sorted out on the car, I am really starting to drive her more and have just started to play with the programming. I have a G-Tech A/F Ratio meter hooked up, I know this is not accurate enough to do an accurate tune, but I am trying to get the car less rich, it is full rich across the board all the time. I have done some programming and what I have learned so far it is a fine line between rich and lean, I am erroring on the rich side, but i have set it so if I turn the knob on the control to lean, I can see the results on the A/F meter. I have been mostly concentrating on the lower throttle or cruising settings, just to get the fuel mileage up. But I have a few questions. 1) at idle, I am reading rich, and as I lean it out I get a vibration from the engine, but if I richen it, the revs start to drop and you can her the engine boug a little. Any ideas? 2) When the temp gets cold (below 40 f) the car does not want to start (with a cold engine), other than this it starts fine, I have adjusted the engine temp for the mis-reading of the sensor, but I have the cold debur only to about 20, should I try to set this higher?
Thanks!
Thanks!
Two things affect start-up:
1. The 8 sec, or so, enrichment - think I have mine at 11.
2. The enrichment as function of water temp.
I suspect you need to play with 2 to get better cold start. Should be simple. Good luck.
Thanks Jes, I kicked up my enrichment to about 20, but I think it is too high because when it is warmer that car stumples for about 8 seconds, then smoths out, so I guess I need to play with enriching the water temp. Have you messed with the air temp enrichment? My car idles about 200-400 rpm higher when it is cold out...
Yes, I have adjusted both air temp enrichment and water temp enrichment. I adjusted the air temp enrichment in order to maintain A/F ratio (before turning on closed loop) when car sits idling accumulating hot air (and taking it in) compared to running on the street IN THE EXACT SAME environment, i.e. 2 min later, and then stop (it then idles with colder air for a short while). Without this adjustment it would idle with different A/F ratios due to the change in air temp. Though, a somewhat tedious process...
Of course, it is never really that cold here (in So Cal) - was in the 80s last week
