Hey,
I'm starting my 3.0 ltr motor conversion for power as I'm finishing the suspension and brake upgrades. I've got access for a Verde 3.0 ltr block and 164 3.0 ltr cylinder heads. I know the distributor housing has to be capped off on the 164 head. Will these heads fit the Verde block without too much mods or what mods are needed?
brookstroutr
164 Heads on a Verde 3.0 ltr Block
Regards,
N. G. Brooks Robinson
'84 GTV6
'84 M635CSi
'84 GTV6
'84 M635CSi
Hi,If you do a search you will find the topic has been covered..
Briefly,head stud outer holes need to be ream larger,dowel pins need to be offset slightly,shorter studs need to be fitted..
brookstroutr
Zman,To retro fit the 2 heads tkes a few minor mods..thats about it..
Sometimes you run into hassles with the crank gear as well,but thats minor..
