Ignition
Can any of you suggest a source for the coil and ballast resister for the '81 model. Am performing a systematic replacement of my ignition bits due to an unpredictable ignition. Now you have power, now you don't. All or nothing. I've discovered quite by accident that if I tap on any of the components (power mod., coil, or resister) with a rubber mallet, often, my ignition will return. Replaced the power mod., ignition switch and cleaned all connections, etc. Still, the ignition may or may not 'turn on' for lack of a better description. It's like the girl with the curl ... when it's on (or good) is very good, when it won't turn on, its horrid. Any suggestions on the problem appreciated. Any suggestions on a source for the coil/resister also greatly appreciated.
