- ALFA GTV6 GP
Autodelta straight cut gearbox
Autodelta straight cut gearbox impulse buy...
Anybody on here used on of these boxes ?
What can I expect ?
Will I like it hate it?
Pros and Cons please?
What can I expect ?
Alfa GTV6 3.0 (Silver)
Alfa GTV6 GP 3.0 (Red)
Alfa GTV6 GP (Concourse)
- ALFA GTV6 GP
Yes Mats will be mated to a ex Colin Bond Group A motor I just bought to go in in my GTV6 race car I am building.
(I just wanted the motor but the seller prefered to sell as a pair)
I just read Straight cut gearsets are relatively noisy in operation and have an inherent whine to them.(Sounds like my exgirlfriend)
- Dennis
I don't know about your ex, but the box won't break when you run it hardALFA GTV6 GP wrote:Yes Mats will be mated to a ex Colin Bond Group A motor I just bought to go in in my GTV6 race car I am building.
Now on topic: That's a nice find. The box probably has some nice short ratios and a short diff ratio
'81 GTV6 3.0 QV
'91 75 TS (track)
'02 BMW 330i Touring
'91 75 TS (track)
Too bad your in Autralia or I would have been on my way over to buy that box from you!ALFA GTV6 GP wrote:Yes Mats will be mated to a ex Colin Bond Group A motor I just bought to go in in my GTV6 race car I am building.
Just listen.ALFA GTV6 GP wrote:Yes Mats will be mated to a ex Colin Bond Group A motor I just bought to go in in my GTV6 race car I am building.
http://www.youtube.com/watch?v=9aP4e1F85zc
But seriously yours will sound more like so:
http://www.youtube.com/watch?v=iUahFIeThbE
- ALFA GTV6 GP
Alfettish same engine and gearbox as the Dulux beast.(Not alot of power but was extremely reliable)
Diff ratio is 4.1
fithth is 1:1
diff locked at 90 percent.(All the info I have at this point)
I am aware of the autodelta close ratio gearbox variants : 2.54,1.94,1.55,1.22,1.0 gear ratios with final drive of either 4.1, 4.545, 5.125, 3.5 (v6 size),
-straight cut gears with bearings on all gears and standard synchros with inbuilt oil pump spraying cool oil on each gear and on diff gears too.Some had 75% Lsd.
Dennis go hard or go home is the moto for this engine ha ha
Mats come down to Oz and teach me how to change gears with straight cut gears ! do I match Revs and Double clutch or just match revs?
as I said impulse buy.....
Diff ratio is 4.1
fithth is 1:1
As you say they retain the std synchros you shift as you would on a normal tranny. All the gears are meshed 100% on both boxes and you only lock them to the axle when you engage the sleeve.ALFA GTV6 GP wrote: Mats come down to Oz and teach me how to change gears with straight cut gears ! do I match Revs and Double clutch or just match revs?as I said impulse buy.....
Is the casing identical to a normal transaxle? Or, do you have a reinforced casing (clutch, diff, etc)?
Nice find you have there! Put me 2nd in line if you want to part with it.
- ALFA GTV6 GP
The engine and gearbox is not in my possession yet I will check that out and get back to you.
I have recieved a pic of the engine bay! Its running a strange air intake as regulations stipulated you ran a plenumn..
Ex IGNIS car Group A Motor 2.5 @ 200kw or 270HP.
- 09122007.jpg (48.91 KiB) Viewed 9821 times
christiaan
