ALFA GTV6 GP
Autodelta straight cut gearbox
Post by ALFA GTV6 GP »
Autodelta straight cut gearbox impulse buy...
Anybody on here used on of these boxes ?
What can I expect ?
Will I like it hate it?
Pros and Cons please?
Alfa GTV6 3.0 (Silver)
Alfa GTV6 GP 3.0 (Red)
Alfa GTV6 GP (Concourse)
A friend had one, great for race cars, absolute nightmare for street cars. :wink:
ALFA GTV6 GP
Yes Mats will be mated to a ex Colin Bond Group A motor I just bought to go in in my GTV6 race car I am building.
(I just wanted the motor but the seller prefered to sell as a pair)
I just read Straight cut gearsets are relatively noisy in operation and have an inherent whine to them.(Sounds like my exgirlfriend) :roll:
Dennis
Post by Dennis »
ALFA GTV6 GP wrote:Yes Mats will be mated to a ex Colin Bond Group A motor I just bought to go in in my GTV6 race car I am building.
I don't know about your ex, but the box won't break when you run it hard ;)
Now on topic: That's a nice find. The box probably has some nice short ratios and a short diff ratio 8) Noisy as hell, but you won't notice that whit your helmet on. Otherwise, buy some earplugs!
'81 GTV6 3.0 QV
'91 75 TS (track)
'02 BMW 330i Touring
Too bad your in Autralia or I would have been on my way over to buy that box from you! :)
Alfettish
Post by Alfettish »
Just listen.
http://www.youtube.com/watch?v=9aP4e1F85zc
Alfettish
Post by Alfettish »
But seriously yours will sound more like so:
http://www.youtube.com/watch?v=iUahFIeThbE
ALFA GTV6 GP
Alfettish same engine and gearbox as the Dulux beast.(Not alot of power but was extremely reliable)
Diff ratio is 4.1
fithth is 1:1
diff locked at 90 percent.(All the info I have at this point)
I am aware of the autodelta close ratio gearbox variants : 2.54,1.94,1.55,1.22,1.0 gear ratios with final drive of either 4.1, 4.545, 5.125, 3.5 (v6 size),
-straight cut gears with bearings on all gears and standard synchros with inbuilt oil pump spraying cool oil on each gear and on diff gears too.Some had 75% Lsd.
Dennis go hard or go home is the moto for this engine ha ha
:lol:
Mats come down to Oz and teach me how to change gears with straight cut gears ! do I match Revs and Double clutch or just match revs? :oops: as I said impulse buy.....
Alfettish
Post by Alfettish »
Upshifting just slam the gears home.
Downshifting I would doubleclutch.
ALFA GTV6 GP wrote: Mats come down to Oz and teach me how to change gears with straight cut gears ! do I match Revs and Double clutch or just match revs? :oops: as I said impulse buy.....
As you say they retain the std synchros you shift as you would on a normal tranny. All the gears are meshed 100% on both boxes and you only lock them to the axle when you engage the sleeve.
ar4me
Post by ar4me »
Is the casing identical to a normal transaxle? Or, do you have a reinforced casing (clutch, diff, etc)?
Nice find you have there! Put me 2nd in line if you want to part with it. :wink:
ALFA GTV6 GP
The engine and gearbox is not in my possession yet I will check that out and get back to you.
I have recieved a pic of the engine bay! Its running a strange air intake as regulations stipulated you ran a plenumn..
Ex IGNIS car Group A Motor 2.5 @ 200kw or 270HP.
christiaan
Post by christiaan »
Where can i find such a gearbox ?
always fast
