AlfaTipo
Platinum transaxle speedo confirmation
Post by AlfaTipo »
I read Michael's tranaxle FAQ and just need to confirm something.
I picked up a Platinum transaxle yesterday and have the amplifier along with the Milano speedo.
In Michael's article he mentions an 86 or late 85 speedo will also work. Car in question is a late 85 with iso linkage. Build date is November 84.
I'm not near the car to check the sender, is it the same as the Milano with an amplifier?
I have the chance at a 86 GTV6 speedo. Would that be better?
Jef
www.motozane.com
sh0rtlife
Post by sh0rtlife »
just pick up an sgi-5....have a look on ebay..there are 2 dealers and you can pick it up for under 80$ shipped
franksun
Post by franksun »
sh0rtlife : You know if the sgi-5 will work on a GTV 116 82-model?
Regards
Frank
sh0rtlife
Post by sh0rtlife »
well my 83 has all of the older 82 style stuff so...hell my build date is 2 of 83
the sgi-5 is litteraly designed to work on ANYTHING
franksun
Post by franksun »
Mine is like this: And this is the broken part:
WIll it be able to replace it?
sh0rtlife
Post by sh0rtlife »
your going to have to find another sender then off another milano..doesnt need to be specific to a platinum tho
is it non functional and are you sure you had it wired correctly?
franksun
Post by franksun »
Yea its wired properly :) It is from a AR gtv 2.0 116 82-mod
Frankson
No it isn't wired properly because :-
The sender you are holding was never fitted to an 1982 GTV. It will certainly NEVER work with an 1982 Veglia speedo without a signal converter like the SGI-5.
It may be ok but the missing converter means it cannot work.
Please do a search on speedo fixes in this forum for heaps of advice.
franksun
Post by franksun »
Wow, OK MD, thanks for the info...
The sender was in the box when i bought the car, the speedo never worked, that may explain it
sh0rtlife
Post by sh0rtlife »
which is why i asked if it was wired right....in some cases you need the amplifier AS WELL as the sgi-5 box
