After checking all the indicators and front and rear lights, I realised that the rear fog light is not working (my car has only one rear fog light). I checked the contacts with a polimeter and found that there are 7 volts (shouldn't be 12?), so I tried several bulbs (one pole 21W, one pole 5W, twin pole 21/5W), because that would be enough tension to make them work, but none of them showed a minimum bit of light.
Anybody can tell me what's going wrong?
Rear fog light doesn't work
'84 Red GTV6 3.0
I checked the ground below the boot latch and it made no difference, so I got the board out and you were right, the mass contacts were loose. I welded them and now it works perfectly. Then I decided to do the same job with the other board and now it's better than ever
Thank you very much!!!
'84 Red GTV6 3.0
