What's the compressed thickness of the Headgasket?
What the COMPRESSED thickness of the 2.5s head gasket? After I torque the head and take it out it's around 1.7mm but I am sure it's thinner when under the torque of the headbolts.
I am having some thicker headgaskets made up for my new 2.5 and need to calculate the needed thickeness for the desired boost level.
Ive always measured 1.7mm Greg.
Thanks Barry,
I would think it would be thinner then 1.7 since that's what it is when removed from a running motor. Still, I will go with that number and take accurate compression ratio measurements before and after the thicker headgaskets are in.
