Barry,
Question:What is the biggest front disc + caliper combo i can fit with standard 6*15 campagnolo wheels?My current setup consists of standard GTV6 Brembo calipers+ standard GTV6 discs as well (in a 2 liter GTV though).
Respect.
P.S: Can we have some photos of the white beast i see in the small picture under your forum name?
Respect.
Jim,This chap is using old original ,I think,Gotti race wheels on this car.Im also making them fit the Compomotive cx and fh split rim.
I cannot get a 305mm AND the caliper in there..Ive just fitted a std Campagnola gtv6 rim and I can tell you that it does not go over the rim either...
Maybe a more modern rim will go over bigger stuff...its posible,but 328mm???????????????????????????
See all the q marks??you sure,Mr Scnitsel??
- DSC00027.JPG (153.17 KiB) Viewed 10260 times
Zissis,check the performance thread by matt with his turbo..I posted pics there...
- f2_1_b.jpg (21.16 KiB) Viewed 10259 times
Hey Barry,
Wanna put that bottle down for a while until you can talk some sense??? I'm having a hard time reading between hiccups!!
I can send you them pics again if you want. Like I said, 310+reds for 15"MO's and 323+reds for 16". As you say though, the Compomotives are one of the roomiest wheels around.
These wheels,btw,are Speedlines,not Gotti`s..They also have NO place to fit a half descent set of brakes within them..damn,I had to cut the 310mm disc down to 297mm AND mill some off the Brembo calipers....
A bitch wheel if I ever saw one....
Everything fits perfectly under the std. 30l Compomotive without any mods,but the client wants the option of both sets of wheels..
- DSC00042.JPG (152.27 KiB) Viewed 10177 times
I'll try to post some pics here, lets see if it works out.
- Another bracket idea for Brembo Reds.
- P2240005a.jpg (126.49 KiB) Viewed 10137 times
- Note caliper spacers to allow 32mm thick discs.
- P2240001a.jpg (116.5 KiB) Viewed 10139 times
- Assembled view.This is good for 310mm discs.Bracket can easily be modded for 323 discs.
- P2240004a.jpg (109.97 KiB) Viewed 10141 times
