Jose I
wheel fitment
Post by Jose I »
Where can I find those lug nuts with the floating seat, to fit 5x100 wheels on a 5x98 bolt pattern, If not I might have to go with the serpant auto wheel spacer with different bolt patern. I realy don't want to do that because space is all ready an issue with these cars.
Drive'm Hard
Alfa GTV6 NZ
Post by Alfa GTV6 NZ »
The ones i got mere made by Momo.
So try find someone that stocks Momo products.
Best of luck.
Karl
OZ Racing had them as well.
You can't get these things in the US.
My suggestion is either to permanently change your hub configuration or just modify your wheels. Where I live it only costs me $160 to modify a set of wheels from 5 X 100mm to 5 X 98mm and bore out the center bore from 57.1mm to 58.5mm (basically a VW VR6 wheel to fit the Alfa).
Jose,MAKE them yourself.....a lathe,mild steel for the conical washer,and high tensile wheel bolts....
DSC00003 (2).JPG (131.9 KiB) Viewed 5221 times
