Terry Johnston
Ansa Perfomance Center Exhaust
Has anyone out there tried the Ansa Perfomance Center Exhaust that eliminates the middle resonator and is used with either the stock tailpipe are the ansa product? Curious if the result is just a louder exhaust or there are noticable perfomance improvements. Terry
Terry
Hello..
I have the CSC Center Exhaust (see photo)Its works great and give a great sound
Here is where i bought it: http://www.ebspares.com/
I think this is a csc product..you can get the csc center section in 3 different sizes...Look at this page:
http://www.alfetta-gt.de/ADhome1/club/a ... uff-6.html
MerrilGordon
So Norway (or anyone),
Was the CSC center exhaust substantially louder ?
I need to replace my center exhaust as it's worn out. I'm pretty sure I'd simply like the stock type as the fitment is good, but called IAP and they didn't have any and were having problems getting them in.
Any other suggested sources for the middle muffler ?
If the Ansa or CSC wasn't any louder I might consider it. I am also concerned about ground clearence past the aft structural support.
Merril
Merril
82 GTV6 3.0
Hello....
on my car it didnt get any louder,thats becouse i have the csc rear silencer to..and that is realy silent!!The ground clerance got even better on my car...thats maby just becouse i got new rubber rings.
I have frends that couldnt use it becouse it got to mutch sound(music)
.But thats just with stebro rear silencer.
So...just go for it
So...just go for it
MerrilGordon
Thanks Norway,
I've got an Ansa exhaust on the rear and although I like my GTV6 to sound good, I don't like it loud so I am concerned about extra noise. Maybe I'll search around for another source for the original type center section, if I can't find one, then I'll likely go with the straight through type like the CSC.
Merril
Merril
82 GTV6 3.0
John in Denver
MerrilGordon
Maybe you guys should look into exhaust valves. Look at the new BMWs, specifically the E36 328i or E46 330i. Look at the muffler and you will see that one of the 2 tailpipes has a small valve which open and closes depending on some triggering event (vacuum, throttle angle, etc). But you can configure a similar setup so that it partially closes at low throttle angles (cruising).
On the web, do a search for exhaust cutout valve .
Be creative guys.
Be creative guys.
