The most significant mod is the rev limiter set to 7250 rpm´s.
It´s usefull when racing because despite you´re not getting more power after 6000rpm, you can push it further just between corners.
With this I mean you don´t have to change gear just before a corner just because you hit the rev limiter.
Sorry about my english
You know, my friend had a GTV6 2.5 with stock bottom, modified ECU and just QV cams. He revved that thing to 7.2K rpm nearly everyday, and at least a few times a day. Nothing happened to it. I'm sure you will wear it out quicker than if you were to drive it up to 6.5K rpm only, but otherwise it was still very much alive years later. Maybe I'm just paranoid about these things.
Dude, I don't even have a reliable tach right now. Luckily I have my fantastic ear and in perfect sync with my calibrated seat-of-pants dyno I just shift gear when the engine fall off cam, sounds like 7500ish but maybe it's more.
Std cams so it really doesn't pay to rev it too much.
Mats Strandberg -Scuderia Rosso- Now burned to the ground... -onemanracing.com- -Strandberg.photography-
