Alfa 75 Turbodiesel radiators.
Hi guys,
I thought some of you may be interested in this. I found (looking through eBay) an Italian rad maker selling the TD rad for 120Euros. I just ordered one (although I already have a spare)-you don't know when these things will cease to exist.
Look in: http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... %3AIT&rd=1
I strongly recommend you look into it and if you get it, fabricate a simple twin-fan setup, as its highly unlikely you'll find an original set (outside Eu)
Rad: 6kg
Twin fans+shroud: 5.5kg
Hey Micke, most of us drive our cars on the street, trying for the impossible compromise: road+track car.
Thats why we keep a/c, twin fans, radios...if with all this we can manage great laptimes, so much the better! (Rich dudes and Finns have dedicated track cars!)
I only wear what FIA tells me to wear...
Micke, you have a 4Kg radiator? Jeez you're such a loser.
I even have a radiator that lets me use a shorter hose, easily one Kg less water...![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Screw Nitrogen, you guys should be filling yer tires with Helium,heheh!
THAT oughta save ya some weight! Plus, you can use body painting into fooling the FIA THINK you have a suit on, eeeehahah!
You can probably also lower laptimes by yelling "andele-andele-arriba-epa-epa-andele!" or "beep-beep"
JK.
JK.
Micke wrote
In Oz the tarmac can easily be 55C with 90% humidity in summer and so heat scrubbing from the radiator has to be more efficient by increasing air speed through the radiator fins. This means one or more fans.
In the case of JK, well he doesn't really need a fan cause he is full of piss & wind already.
How's it goin' Jim you Greek Duck dater you. ![Laughing :lol:](./images/smilies/icon_lol.gif)
Generally agree with that but I also think you need other contigencies to allow for climate and seasonal changes and when you go racing.eg. in your neck of the woods, I dare say that the ambient air temp would be failry low with low humidity. So your weight saving set should/does work.On the track you don't need double fans anyway. Not even a single. The fans are just for crawling around or idling in traffic lights.
Doesn't increased humidity make the situation better? Better heat transfer in any case, this also is why it feels hotter outside in OZ (summer) and colder outside in Sweden/Finland (winter) when it's moist.
The asphalt can easily get to "sticky-shoe-temperatures" here too in the summer but moisture is fairly low, or very low depending who you ask I guess.
The fans do absolutely nada for airflow through the radiator unless you're driving less then 10Km/h or so.
Good to hear from you JK. I never knew how unique a guy you really are mate. You're the only one I know that needs to sit on a 75 OD cork plug to keep his brains in. In think there may be an award for that.!
Mats if your fans arent' doing jack, you must have them mounted in the boot. If you still have doubt get a hot wire anamometer and probe in the front of the radiator when the fan is running to get a revelation. Of course there are fans and there are fans. Unless you have a decent shroud encapsulating the radiator and the fan together, the efficeincy of the fan will fall off dramatically. It also pays dividends if you block off any by passing of the airflow around the radiator at the front of the vehicle to force all air through the radiator only. (Fan or no fan)
I think you could be dicing with engine failure even in a race car if you have no fan at all. That kind of weight paranoia is in my opinion counter productive.
