PietereQ
Need new servo...
Post by PietereQ »
Well, servo on my GTV6 is dead, and my question is, can I swap servo from 75/Milano? Are they the same? Will it be a bolt-on install? How much would such part cost? Any suggestions?
Pete
PietereQ
Post by PietereQ »
C'mon guys I can't believe you don't know the answer... :wink:
You mean the brake booster?
David
Post by David »
Pete,
If you do mean the brake booster, Two I have, one from a GTV6 and one from a 75 look identical, same part number. See photos below.
The GTV6 booster came from an accident damaged car and one mounting bolt is missing.
David
GTV6 on Left
GTV6 on Left
GTV6 on Right
GTV6 on Right
Boosters 2.JPG (69.88 KiB) Viewed 13157 times
PietereQ
Post by PietereQ »
Great guys! Thanks! That's exactly it! Sorry for the word term "servo" which might have been misleading, I just thought that since it's certainly not a Polish word, and as it is with most of automotive vocabulary, it has to be derived from English :oops: Do you think that brake booster can be rebuild? Or I should better look for new one?
We call it the same thing in Swedish. :wink:
The 4-cyl booster looks much flatter and has a bigger diameter on the 75.
Get a new (or good used) one.
PietereQ
Post by PietereQ »
Yesterday, I talked to a nice guy which apperaed to be an alfisti with quite serious alfa collection, he has offered me such servo for circa 35 Euros. Quite decent price I think.
OT,
Mats,
And as far as linguistic similarities are concerned know it's the same thing with such words like "kula", or "smak" :wink:
PietereQ
Post by PietereQ »
Well it's me again. Fitted the new servo and the difference is minimal. I know that stock gtv6 brakes are not Tarox 12 piston brake kit, but it should be much sharper. Do you have any suggestions what may be the issue?
PietereQ
Post by PietereQ »
I'm counting on you lads...
The stock brakes on the GTV6 should work very very well. If not, start by looking at the check valve on the driver's side of the intake plenum. If it's not functioning correctly you won't get much power assist. Of course the vacuum line from the boost to the check vavle has to be good, and the engine has to be generating enough vacuum at idle.
If all of these things are ok, and the booster is functional, it's a caliper/pad/adjustment issue.
PietereQ
Post by PietereQ »
Thanks Greg! I'll try.The symptoms are that the brakes are very spongy, and it really requires a great deal of force pressing the brake pedal to slow the car down, can some air leaks of the hose be responsible for this?
I'll take a wild guess and say you brake hoses have never been changed. I changed them on my 75 when I bought it and i made a HUGE difference (quite cheap too).
Daniel
Post by Daniel »
I agree with Mats, look at your hoses. I've seen a hose that looked like it had swallowed a whole egg when you pushed the brake pedal hard. Pedal felt kinda spongy :shock: Wasn't on my car !!
PietereQ
Post by PietereQ »
Checked the the vacuum hose and brake hoses - they're ok. Guess I have to surrender and visit the mechanic :( Damn, and I hoped to save some money... Anyway, thank you all.
