I've read that some modifications are required to install the MS I V2.2 on my L-Jet GTV6. I've been told that I must do the following:
1. Substitute R10 and install a 1K6 ohm resistor instead.
2. Substitute the 1N4001 diode and install a 1N4004 instead.
3. Substitute C12 (0.001 uF) for a 0.01uF one.
4. Change R4 and R7 (2k49) for 2k2 resistors.
5. On step 54 (assembly guide) do not jump, but wire XG1 to the L-jet box.
6. Do not install D7, D22 and D23 diodes.
If I don't install those diodes, do I have to jump the circuit or leave it open?
What else do I have to do???
