Hi Lennart, I had problems at the bottom flange where the three pipes join into the down pipe( 50 - 60mm pipe) to go past the sump. Because the flange surface area was mot very wide i got a small air leakage which resulted in blowing the gasket so I remade the bottom flanges on laser with a slight insert in the direction of the flow to stop this. Main problem is that only two studs hold this flange as there is no space.
I will put pics up on exhaust thread tomorrow.
Ciao
Ciao
Hi Lucass, a forced induction motor is very reliable if you got the correct cooling under the hood, timing set up and regular oil chainges. My Dad had the highest mileage Alfa super turbo in our club with nearly four hundred thousand km on the clock over ten years. Believe it or not. Turbo was replaced three times, head off once to remove manifold studs otherwise no other issues. The car mainly travelled long distances at a time over South Africa to our construction sites(norally in the middle of now where).
If was you I would go with the super charge route and if you wanted more and got the know how take your 2.5 up to 2.8 using3.0L pistons and sleeves(boring block).
One of the pics Andrew took of Roberto Giordanelli in my original GTV3.0l.
This car has never been touched, note the high ground clearance.
Andrew took a whole bunch of great pics of an assortment of Alfas on the track that day including the Glenwood 3.7.
Hopefully he will put them up or let us know what mag they will be especially the Carabeneri Giulia.
- IMG_9338.jpg (37.09 KiB) Viewed 13548 times
Its interesting how technology has chainged ones approach to motoring. My wife(also ex kart racer) and I took the GT diesel and the GTV3.0l(original) on a small trip to the bush which has a lot of twisting winding roads to get there. Thank goodness the old carb GTV was quicker on acceleration and only just!
From 150km to 200km/h the GT diesel is extremely strong (that 300nm of torque) which makes it fun to drive through the passes. The only problem with the diesel is that you chainge gears at least twice when passing someone which doesnt let you settle down and get into a good driving rythm through 40km of twisting corners as in this case. This is where the GTV came into its own.
A decision had to be made which car had to be taken into the Kruger Park and it was obviously the GT. Note the Kruger Park is bigger than the United Kingdom and only a 40km speed limit with only one garage in it so rather than running out of fuel with those petrol sucking carbs and poor aircon , we went with technology and refinement.
I would never have done this fifteen years ago.
Two pics to follow. Nearly got stood on by an elephant , not sure which car would have been better off in!!
- Img_1714.jpg (149.88 KiB) Viewed 13317 times
- Giulietta24vTT
- SydneyJules
Jules, how you doing ? Hows the the 'screamer' (your car) , are you still scaring the Jap cars?
My wife in Sydney at the moment enjoying your great country. She staying at my sisters place where you and Ben dropped me off. As the saying goes 'while the cats away - its been a two week Alfa frenzy of finishing a tiresome 3.7 24v, fine tuning the race car, and putting the other 3.2 24v into race spec for next month. Just a few pics for update.
- IMG_1911resize.jpg (96.28 KiB) Viewed 12037 times
Standard 2.5 with RS kit , semi slicks on widened rims. Best fun to drive in race conditions . No extra power to help out when you make mistakes but very competitive in the middle of the field. Car is usually covered in sponsors stickers but I remove them after each race.
- IMG_2379.JPG (58.63 KiB) Viewed 12034 times
My goodness, when i saw the first the photo i was like, "Thats what i want!" A driveway full of alfa's!
Indeed they are in amazing condition
Through this website its amazing to see how many of us love these cars from every corner of this globe we sit on
Now i will read rest of threads, once i saw first photo just had to post!
Great pics, thankyou very much!!
