Papers say this 90 have 2.5 V6 engine, but, after seeing it, one friend said he think it's a 2.0 V6 engine. What is the best way to determine which engine I have ?
Nope, all 2.5's of that era had the GTV6 / 75 / milano intake.
I didn't even know the 90 came out in a 2.0 It was 2.5 only in Australia - we never got the 2.0 v6 in anything.
I'd love to see some close ups of the intake and injection on that one.
I will post a detailed pictures whet it comes home, in a few days.
Any idea where I could find 2.0 V6 specifications, e.g. what parts could I use on my 3.0 GTV6 ? Jetronic type ? And yes, I'm thinking about those cams ...
I wonder if standard (mild) suspension upgrade path would be the same as on 75 ? Poly-bushings + bilsteins all around?
Are all (mechanical, except for engine) parts compatible with 75?
I see 90 is generally considered as a "couch" compared to 75. What causes this, thin torsion bars ?
Since I was thinking about setting-up one 75 (in addition to gtv6) for a daily driver, I don't have a problem beeing a bit different and using a 90 in that role, if all the parts are swapable with 75.
you will find they are nearly exactly the same in regards to suspension. i have actually done the opposite before and used parts from a 90 to fit onto my 75.
The throttle response should be good then. This setup should work really well on a 3.0 V6, although the size of the throttle and plates needs to be increased.
are those runners plastic or r my eyes playing tricks on me? id love to buy a setup like that for a project im working on in the future after i dom my turbo. id use it as a base and expand from there.
