Luis
Ignition map.
Post by Luis »
http://www.powerpage.dk/tuning_ignition ... rator.aspx
Any tips for 1.8 turbo engines, and 3.0 v6 12v as starting point?
Wich values? i´m planing to put Edis+megasquirt on the engines.
I would suggest for the V6:
WOT values:
1000 rpm: 10 BTDC
2000 rpm: 15 BTDC
2000 rpm: 20 BTDC
4000 rpm onwards: 25 BTDC
Should be safe with good performance.
For low load, you can increase the ignition advance. I think even in the high 30s is ok but for LOW LOAD only.
Luis
Post by Luis »
http://www.powerpage.dk/tuning_ignition ... p_v106.xls
Well, i mean this configurator for a starting map.
What about the 1.8 turbo?
