Thanksss
For the street,leave it standard..rz wrote:to much!!!mine was lightened to 4.7kg in front and the rear one was also done,threw the front away!! man, is this worthless!the momentum of the engine is gone.if you lighten the front about 3 kg you will notice it ,but not enough and it will cost you to much for the result.
plus the balancing.....
i will never do it again
