GTV max tire size
This could be posted under tires I guess, but as it probably goes under the category "don't try this at home", I'll put it here instead.
I think I maxed out the tires on the GTV with original wide body. The clearance is minimal as can be seen on the following pics.
Tire size is 225/50R16 all around.
ET is 25 in front and 16 rear.
Rear it would be possible to use wider tires at the cost of ET. Hence 245/45 should fit with ET26
Clearance FW 1.jpg (56.6 KiB) Viewed 11096 times
Clearance FW 2.jpg (44.84 KiB) Viewed 11095 times
Clearance RW 1.jpg (52.63 KiB) Viewed 11094 times
Daniel
Post by Daniel »
Micke,
I ran 225/50R16s with 35p offset 8" wide wheels on mine for a couple of days and nearly blew the front guards off it when I hit a bump. Admittedly this was on a road car which used road springs and shocks. Solid links or something near as stiff may have solved the problem or even roads without bumps (don't exist here !!)
I ended up using 215/45R16s instead.
Rears were never a problem.
pancho
Post by pancho »
I am sure this has been asked before but - on a stock gtv6 body what is the max tire/rim size on the front and rear ? :?:
PanchoRama
U5tabil
Post by U5tabil »
I was thinking of getting a 205/40-17 tires on 17x8 rims. That should be good i think...
Fernando
Post by Fernando »
A 205 X 40 X 17 is the same rolling diameter as a 205 X 50 X 15 and with an 8J rim should not be a problem on your GTV6.
pancho
Post by pancho »
205 on an 8" rim is quite streched isnt it ?
PanchoRama
U5tabil
Post by U5tabil »
pancho wrote:205 on an 8" rim is quite streched isnt it ?
Well it shouldn't be when you use R tires, or R Roadtires or whatever you call it. Those are normaly a bit wider than the normal dim. So a 205 R tires is a bit wider than a 205 normal tire. Thats what i have heard.
I have 225 40 16 all around.... no problems, 35 offset , 7.5 or 8 in rim not sure
grant
Post by grant »
Micke, I know it's an old post, but how did you like those Ventusi? How was the tire wear? Do you guys have the Falken Azenis RT-615?
I have a Milano with 16X7.5 ET37 wheels. Do you suppose I could fit 225-45-16 tires on there? The Ventus is available in that size, but the Falkens are not -- 215-45-16 only.
I like them. Didn't drive enough to tell about wear.
The size you propose should be OK I guess.
fastcar
Post by fastcar »
The german Grand Prix version had 225/50R15 on Rial widened rims. (I'm not sure what ET does this have)
Usually I use the 205/45R16 on front and 225/45 on the rear. But a new set of tire waiting for me, which all around 225/45 will be.
grant
Post by grant »
Why did you choose a staggered setup?
