Barry wrote:Does your car start and idle?
If so,is it firing on all cylinders?
Murray
Post by Murray »
s0rr0w if you notice fuel leaking from the rubber hoses between the fuel rail and the injectors you should go no further ! You've got to replace these hoses before you lose your car to a fire :evil:
s0rr0w
Post by s0rr0w »
Barry.
It does start and idle.
When i pull the plug wires out, it sounds as if ther car wants to die..
I'll ma have to get the car to someone that knows more than me..
Will ask the Alfa mechanic if he will come have a look, elswise ill have to take the car to him..
Thanx alot for all the help..
s0rr0w
Post by s0rr0w »
Spoke to the mechanic this morning.
He said that he will have a look, might have a rail there with new rubbers on..
Thanx. :)
s0rr0w
Post by s0rr0w »
Could the leaking hoses have been the cause of all my trouble, that i just didnt notice it earlier, or do you think that there is more to it ?
Murray
Post by Murray »
s0rr0w unless the hoses were leaking a tremendous quantity of fuel that's not likely the source of the problem.Have your mechanic do a fuel system pressure check.In doing this he should also verify correct operation of the fuel pressure regulator.
s0rr0w
Post by s0rr0w »
Thanx Murray.
I will ask him, if he will do the test for me..
Let you know. :?
