A 'budget' race car is born (slow delivery)
There is an Alfa series here in South Africa called the Tropheo series where you can enter any pre 1986 Alfa. There are vert few limitations as long as the cars look the part, ie no aftermaket 17' rims etc. Its a handicap event so it does not matter what you do to the motor or suspension.
I was going to use my 116 3.2 24v GTA in this , but got all paranoid about trashing it so I decided to look for a very cheap complete GTV 2.5.
Two months ago I found an abadoned GTV2.5 parked near my supermarket . After a few enquiries learned the car had been pushed into the parking bay by two women who claimed the gearbox had brocken. Finally after two weeks I got hold of the owner ( Russian table dancer ) , and we aggreed a price of R4500. (no free dances). How she got the car is another story !
The motor sounds good so at this stage thats all thats going to stay standard. Maybe a bigbore 3.7 motor thats luking in the garage might go in there much later but first the car must handle and stop properly for the first part of the process and season as this is supposed to be the "budget race car' with a roadworthy certificate.
Pictures will follow as in the last few weeks a lot of work has been done.
The first step was to strip the car totally underneath, clean it and give it a coat of paint so you dont have dirt and oil over the assembly of the suspension, gearbox, prop etc. Also gives me a chance to see what needs replacing. Upon doing this I discovered a fair bit of rust in the floor pannels, cills and rear cill. Hence the plan has started to chainge so I figure I must cut all the the rust out. This is starting to become a big job if its gonna be done right.
Budget is creeping but I have managed to borrow two pro's in metal work from a friend for a few days to roll some new panels.
- Img_2036.jpg (89.21 KiB) Viewed 22664 times
Drive way is starting to look like hell but im sure a pressure cleaner will do the trick. I will spray all the internals of the doors as they will be exposed. Some will say cut this all out and save weight but im not going there at this stage . Maybe later on in the season but i mustv get car on the road in a months time.
- Img_2105.jpg (112.53 KiB) Viewed 22633 times
Gees Kev,I missed out on the car AND the Russian table dancer...
Thanks for handing over the keys to Bella at Kyalami yesterday~it was fun...
I need to get a Giulietta up to go play with you...
You owe me a table dance...err,maybe not,it ok...
Baz, Im sure i can get the Russian back for the launch of the car. Anyway we must start a new thread in other and post pics of yesterdays fun at Kyalami. You work the whole year to have fun like yesterday, thrashing the 116GTV( GTA) on an open track, full marshals and only three cars. Funny how it was only us pushing car. More details in other.
I think Kev did some metallurgical analysis and was still not quite sure what to use.He then cut a piece out from the chassis and had it spectographically gas analyzed..It came up with an excotic material that he would have to import from Russia so he just used mild steel plate...
Your right Z, lungs not so good. Normally do wear one. Thought the internals would be a quick job.
The cills are mild steel.
Decided to widen the standard rims by an inch to fit our semi slicks. Nothing new here. Dawie was doing this 25yrs ago with no failures.
Used old 164 rims for the donor inch. This was actually cheepest option(R2500 to cut, weld and test) and I prefer the handling with 15' rims with Rons kit.
- Img_2143.jpg (50.63 KiB) Viewed 22479 times
