hello lads,
when filling up my gtv 6 w/ gas at the pump. I have to go really slow, or it sets off the pump to stop. Any ideas why? I'm tryin to find a fuel supply system techincal drawing but all i can find is the one for the 75 and for a gtv6 for australia. Anyone have the north american version?
Greg Aiello
Re: hard time filling up at the pump
Dont shove it all the way downgrega wrote:hello lads,
Greg Aiello
the only way it will work is if i just slightly insert the pump into the filler neck. And even then I have to go very slow. I should add that i did change the filler neck rubber connector hose. I just used a 2" hose and stretched one side to fit the large side. I don't think that would cause my problem would it? I recall the original part had some sort of bulge inbetween the larger and smaller size hose.
Does the gtv6 have a breather hose or anything else that i should check?
