Hi gang,
In the process of a rebuild on a Milano V6 and I'm having trouble trying to remove the liners. I was able to get 2 of the 6 out but these last 4 won't budge. So far the best way I've found is to tap (lightly) on the bottom with a piece of wood. Anyone have any ideas or tricks to remove the liners without damaging anything?
thanks
AlfaBeta
AlfaBeta Have you tried some heat ? Take a propane torch and work the flame around the base and then give your wooden block a good tap.If you're going to re-use your liners make sure they don't go flying out and crash to the floor.
Or you could simply make up basic tools to do the job with....
- DSC02054.JPG (157.76 KiB) Viewed 5858 times
- DSC02053.JPG (157.27 KiB) Viewed 5857 times
Got em out!
Hi guys,
I little heat gun on the block worked like a charm, they came right out with a couple light taps!
thanks a lot
AB
thanks a lot
AB
