Anyway back to my flimsy cage. Md you can see if you look closely under the cages brackets, there are the 5mm plates welded. Not hard to miss that welding(the brackets are all painted white. The wheel arches have plates welded in from under the arches also with the nuts welded to the plates as in all the others. pic to follow
- IMG_2368.JPG (74.89 KiB) Viewed 9663 times
Digressing a bit, did some testing today and found the waterbottle severd its 25yrs . Replaced with a chev bottle. Not a great fit but does the job. Must get the correct cap for waterbottle and install the over flow bottle(regs). If anyone is going to do this(use chev bottle) in their road car make sure you dont use these high pressure caps as our heater systems cannot take it and will burst. These high pressure caps are normally 1.7 to 2 bar and our specs here on the origional cap is 0.7bar. Also found the T piece behind the engine had totally rusted closed. You can see if its blocked if you rev the motor and no water squirts into the bottle(small hose on top side of bottle).
- IMG_2367.JPG (106.22 KiB) Viewed 9662 times
Kev, Matts, everything is not what it seems first sight. Feedback from you Matts is relevant on the basis of what you see which is not enough. So I have added a couple more frames to illustrate exactly the points you expect to be there and then some..
The base of the mount is effectively a 6mm box section and it cannot collapse nor can the 16mm high tensile bolt sheer off as the base connection is restricted from any sideway movement by other components. Also not shown are other cross bracings to expressly cater for side impacts.
Yes, my half cage on this vehicle is for road use only. Hope that clears it up.
- LHS Main Hoop Connection with Cross Brace.jpg (236.86 KiB) Viewed 9662 times
- Cross Brace at Hipline.jpg (238.15 KiB) Viewed 9663 times
I finally made it to the track on Saturday morning for the first race of the season. Got through scrutineering with no problems so they are no blemishes in the log book. Unfortunately I did miss free practise on Friday.
I have only done eight laps on this circuit previously and four of them were with Ron Simon so Qualifying session was a very fast learning curve. The car handled brilliantly and was very neutral. As I am running a stock standard 2.5 motor the racing proved to be a lot of fun (and close) as most of the other Alfas were all two litre light weight Bertone GTV's. There was one other GTV6 2.5 which was a lot stronger on the straights but with the RS kit I could make it all up in the corners.
Only problems was in second race, the modified water cap broke and lost lot of water but thats easy to sort out.
All in all it was well worth the effort and hopefully this motor stays together for a few more races.
Will post pics.
Building car two now with the bigbore motor. Nearly done but been a nightmare(had every possible problem with the block regarding to head bolts) Pics to come.
Will post pics.
- SydneyJules
"You're a tireless man!!"
See the thing is Jules, over there in SA you cannot afford to sit on your arse cause they have hungry lions and tigers that sneak up on you to get a piece of the action but planting your arse in a race car sort of evens out the equation.
..what, you didn't know that ? Geez. I thought pilots waz smart too.
So for Kevin this is not about fun, frivolity and hot chicks that wanna massage your clutch. Hell no !! It's about survival !!
Set him straight will ya Kev ?
Hey Greaseball. If you could learn to spell, you would learn some amazing things like the verb tire means fatigue,weary, exhaust, jade and dare I say, fag. Your mother warned you about dozing off in English class...
On the other hand ( in your case either hand) tyre is the big black doughnut around your rims with lots of air in it much like your cranium.
Having said that, you being Greek, I will forgive you just this once.
Ever heard of Webster's dictionary? Or how the Engleesh language was improved ever since the limeys left the US alone, heheh! Tyre my a$$, its tire, and 280 million people agree with me! We iz more of you so we iz right!
Bull like colour and stuff and how do you clowns pronounce: lootenant, heheh!
Speakin about inklis. I know this is OT but seems this is all BS anyway.
Having chosen English as the preffered language in the EU, the European Parliament has commissioned a feasibiblity study in ways of improving efficiency in communications between Government departments.
European officials have often pointed out that English spelling is unnecessarily difficult. For example: cough, plough, here, hear, bow, bough, through and thorough.
What is clearly needed is a phased program of changes to iron out these anomalies. The program would be administered by a committee of top level staff chosen by the participating nations.
In the first year, for example, the committee might suggest using "s" instead of the soft "c". Sertainly, sivil servants in all sities would resieve this news with joy. The hard "c" could then be replased by "k" sinse both letters are pronounsed alike. This would not only klear up konfusion in the minds of klerikal workers, but typewriters and keyboards kould be made with one less letter, a signifikant saving.
In the sekond year, bekause of growing enthusiasm, it will be announsed that the troublesome "ph" would henseforth be written "f". This would make words like "fotograf" twenty persent shorter in print.
In the third year, publik akseptanse of the new spelling kann be expekted to reash the stage where more komplikated shanges are possible. Governments would enkourage the removal of double letters whish have always ben a deterent to akurate speling.
We would al agre that the horible mes of silent "e"s in the languag is disgrasful. Therefor, we kould drip thes and kontinu to read and writ as though nothing had hapend.
By this timeit would be four years sins the skem began and peopl would be resepti to steps sush as replasing "th" by "z". Perhaps zen ze funktion of "W" kould be taken on by "v" vitsh is, after al, half a "w".
Finaly, zu unesesary "o" kuld be dropd from words kontaining "ou". Similar arguments vud, of kors, be aplid to ozer kombinations of leters.
Kontinuing zis proses yer aftr yer, ve vud eventuli hav a reli sensibl riten stil. Aftr tventi yers zer vud be no mor trubls or dificultis and evrion vud fin it ezi tu understan esh ozer. Ze drems of ze EU vud finali kum tru.
