Watts linkage bushes
Hello.
I require a set of standard watts linkage (4) bushes for my 75. These are no longer available from Alfa UK and I do not want poly bushes. Any idea where I can obtain some??
They can be harsh, for sure.
Thing is though, you're talking about the Watts pivots. A bit different to other suspension pick-up points in terms of vibration transmission. If there's one place you can use poly without compromising comfort, it's here.
My '6 has poly on all 5 Watts pivots and on the DeDion apex. I can't say that there was any deterioration in NVH.
If I were you, I'd call Andy at Performatek and get his take on it.
Ditto.DaveH wrote: My '6 has poly on all 5 Watts pivots and on the DeDion apex. I can't say that there was any deterioration in NVH.
Very crisp handling too. Recommended upgrade. It works because there is not much rotation in the bushings, I know there has been problems in positions where they need to rotate alot and take large loads, like control arm fixing points.
I agree with all these guys. The GTV6 suspension is not like that on your dad's old MG. Poly bushings will not cause a noticeable decrease in comfort. They are one of the few true no compromises upgrades.
Greg,
www.hiperformancestore.com
Greg,
Original diameters of front and rear anti roll bars
Hello!
Anybody knows about the original diameters of front and real anti roll bars on my 75 America? I would like to buy some poly stuff
Peter
Peter
