antifreeze in exhaust
Found a small amount of antifreeze in the oil and antifreeze condensing under the driver side valve cover(probably under both). Engine originally had crapped out rings in number 5 and 6. So, I hope the problem is with the corresponding head...
Only blows white smoke out exhaust when ~170 degrees, maybe a crack in the head opens up?????
no evidence for sunken liner..
you can't see it, but #5 looks like it's running a little lean..
Got a spare head, will change out the valve springs , clean it up, and give it a shot...
- bot1.JPG (182 KiB) Viewed 6651 times
Mats: looks like you were right......I did not see it at first but look at the #5 cylinder in the pic below. You can see the leak and the head gasket distortion....(you can see corrosion in the #5 bowl as well)
Time to get my head milled...
I guess the head is a little warped so I put another on to see what happens (with a new gasket)
- bot 001.jpg (109.81 KiB) Viewed 6535 times
- bot 002.jpg (222.7 KiB) Viewed 6539 times
