Daniel
Timing belt bearings
Post by Daniel »
Can anyone help me out with bearing numbers (SKF etc) for the tensioner bearing and the 2 idler bearings on a 164 24v timing belt.
I just got a price of $412 :shock: for the 3 from an Alfa spares place and had the reaction "F'ken WHAT !!"
Maybe someone has found a bearing off a ford or something that fits instead (hopeful here)
Michael
Post by Michael »
EB Spares in England have the idlers for £29 or roughly US$58.
Tensioner is £104 ($204) and the tensioner bearing is £55 ($108). The latter is a pile of cash for a bearing I agree!
So. in Aussie dollars, for the pair of idlers and the tensioner bearing, you would be looking at £113 which is < AU$280.
By the way, are you thinking NOT to replace the tensioner itself? The one on my engine looks ancient. Do you know when these should be replaced?
I saw some discussion on AlfaBB on bearing numbers. Let me know if you figure out if they can be sourced independant of an Alfa specialist please.
Cheers,
Michael
1981 GTV6
Daniel
Post by Daniel »
Thanks Michael.
I am currently trying to get them direct through SKF - I have the skf numbers for both.
I hadn't considered replacing the tensioner, I was going to set it up using Barry's method - nowhere to go.
Michael
Post by Michael »
Is Barry's method documented here somewhere?
Also, what are the SKF numbers? I can try here locally too 8)
Michael
1981 GTV6
VW Golf wheel bearing,double thrust,so it very good-part number-633296A.
Works as a main 24v bearing AND tensioner bearing.You need to machine up the plug that goes into the center of course.
On the tensioner use 2 std. tensioner bearing plugs,have them ground untill they both fit from opposite sides ,allign and use.
Daniel
Post by Daniel »
Michael -
Tensioner bearing - 633254
Idlers - 2 x 636072
Both SKF numbers.
Barry -
I thought the idler was bigger than the tensioner, does the tensioner have enough adjustment to take this up ?
Borrowed from another site, thanks
24V timing belt bearings.jpg (42.63 KiB) Viewed 6168 times
Dan,so it is...I have had no problems with the bigger dia. bearings I use.As you can see from the pic,this one has been on my engine for ages already.
Daniel
Post by Daniel »
Ok, I ended up buying the tensioner bearing and machining up my own idlers that take 2 x 6203 deep groove ball bearings.
New tensioner and machined idlers
Timing belt bearings.jpg (79.56 KiB) Viewed 5727 times
