Bruce,Hi...No, not a direct replacement.Seeing as your in the UK,get a coupling from Ford for the old 80`s Ford Granada(You know,same as the Sweeney??Hahaha..)
Bolt it on and forget about it.
Cheers.
Cheers.
Uh,Ok...the old roundish(dont laugh here now)one and the later squarish one,both had the essex v6 engine in them..
Gees,sorry bud,Ill try get a picture...
Ok,found them..
Ok,found them..
- 074-429.jpg (2.75 KiB) Viewed 11598 times
- tn_bollock2.jpg (13.53 KiB) Viewed 11586 times
Too small? Pilot dimension or what?
The rubber coupling needs to be dimensionally larger in relaxed position (not mounted), the rubber must be compressed when mounted on the car or it will wear out very fast. The design intent is to never have expanding forces on the rubber, only compressing.
Just the other way around I guess?DaveH wrote:Did you temporarily fit a jubilee clamp while installing? I once tried to fit a coupling after removing the clamp....the symptoms were the same as yours.
