Mats, they are RS. Do you know if a standard 75 rear shock is identical in travel(lenght etc) to a GTV 6. We never got 75's here in SA so I cannot compare. You might know where Im going with this one. Micke what shocks are you using ?.
By the way check out the pic of the worn belt.
- IMG_2385.JPG (54.54 KiB) Viewed 8342 times
As far as I know they are identical, RS? you mean as in the kit from Ron? Maybe you can lower the car a bit?
Are the springs loose at full rebound or are they still trying to extend the shock? What I'm trying to say is that when the car goes to full droop, is there a sudden change in spring stiffnes (as in they slam the shock into full rebound) or does the spring almost fully extend and there is almost no change in spring stiffness? If the spring just about stays put on the seats at full droop I guess you're fine (maybe not if the track is very bumpy) since then you would have to lift the rear wheels completely off the ground with the brakes before you go to full droop.
I have only done that in a military terrain vehicle so I'm pretty sure that won't be a problem.
If there is still serious tension in the spring at full droop it is more likely that you will see fully extended shocks while braking, not good. This needs to be rectified somehow.
X-rad, found the problem with the belt migration after much" pain". The right cylinder head was skimmed at a slight angle by some useless engineering shop. As I bought this as an abandoned car I would have no idea who did it anyway. I will post a pic and you might see the angle it was skimmed by the different heights on each copper plug. Got a race this weekend so I got some busy nights ahead this week.
Mats ,Im going to add a further 20mm in machined spacers to the rear shocks to see if it helps . Cant see why it wont.
- IMG_2387.JPG (58.87 KiB) Viewed 8133 times
Damn, that was a good catch!
I'm guessing the rear shocks are not coil over then.
(Just checking)
Sounds like a plan, have you checked how much extra droop you can add or are you shooting from the hip?
Sporttunergtv6
That "anti-dive" device sounds almost as bad as going to full rebound on the shocks, sure, you still have some individuality left but it's the exact same basic problem - loss of grip because of suspension problems.
