Micke wrote:Let's invert the question:
Why should it be bigger?
On a track, couldn't you get better lap times by having slightly softer spring rates, and using a sway bar to pick up in the roll stiffness? I know brake dive is negatively effected, but over bumps you might have an upper hand over an overly stiff setup?
And Micke, I'm simply trying to learn.
@U5,
Any reason you dind't go with Ron's 4 position adjustable rear bar?
I was originally going to buy Andy's bar (as I'm in the US) but with my 75, I'd have to buy his sway bar end links as well, and at that point the bar was nearly as much as Ron's, all the way from europe.
