GarthW
Can anyone tell me what this is for..?
Post by GarthW »
While i completley gutted out the inside of my gtv6 i came across this hose which just popped out whist stripping out the floor matting near the pedals.
I simply got no idea what it is... :oops:
Selling 1985 GTV6.
GarthW
Post by GarthW »
picture not the best, but have pic of where its from..this is so embarrasing.
Selling 1985 GTV6.
GarthW
Post by GarthW »
hmm
Selling 1985 GTV6.
GarthW
Post by GarthW »
Sorry i'm not on my pc, doing this from other so having trouble resizing images lol.
Selling 1985 GTV6.
Error code 40.
(40cm from the screen that is) :wink:
from the photo you've sent it could be some venomous snake you have over there :)
GarthW
Post by GarthW »
Hehe, luckily no snake!
Will try send better pic soon :)
Selling 1985 GTV6.
brookstroutr
Post by brookstroutr »
Yeah, pics' pretty bad. Is it your A/C condensate drain hose? I also think there is a drain for the front fresh air vents that's located under the dash. It shouldn't be the sunroof drain hoses as they go through the A pillars into the rear of the front wheel area behind the riveted cover plate. I have removed these plates and drilled relief holes at the bottom then re-attached the cover plates with SS screws. This makes periodic cleaning easier.
Regards,
N. G. Brooks Robinson
'84 GTV6
'84 M635CSi
GarthW
Post by GarthW »
Thankyou Brook, thats it! I should have known, for i removed all the a/c hosing, compressor, everything, never to go back in, and that i should have spotted lol. Thanks mate. :) :oops:
I cant believe how much weight is with all the a/c hosing, compressor,
its ridiculous! That with the airbox gone, the 6kg of my turbo is nothing!! :P
Selling 1985 GTV6.
Echo Leader
Post by Echo Leader »
Any idea what the A/C stuff weighs all together??
Sporting Regs. for the SCCA class I'm running in allow the removal of any 'optional' equipment. So if the weight savings is enough to warrent the loss of A/C, I might pull it at some point.
Thanks!
-James
1984 GTV6
GarthW
Post by GarthW »
Hey Echo, will weigh it all soon, need to get some scales for where she's being worked on.
Selling 1985 GTV6.
GarthW
Post by GarthW »
Well the weight with the compressor and all the a/c hosing
was close to 20kg. Around 18kg. :shock:
Also even though i didnt weigh it, all the old shag-pile sound deadener
would have been around 10-15kg. So already have taken nearly 30kg of weight out. Of course new sound matting going in, but will weigh nothing
compared to the shag-pile.
Selling 1985 GTV6.
Post by la_strega_nera »
When I pulled the AC system out of my old GTV I weighed it, the big old iron Yorke compressor, lines, condensor and all the ironmongery to fit it weighed in at 25kg... and removing it made a noticeable difference to the way the car turned in and accelerated. I'd say its definitly wort removing for racing :D
1966 GTV
1982 Suzuki "Bathurst" Katana
