Did a quick draft of an adapter plate. ~315 grams per side.
Made to have the ventilation inwards, otherwise the cold-air scoop might be difficult to mount. nice to have the wall to take up the tension from elongation due to heat though.
Nice pics Mat. Made a whole lot of spaces to widen the rear calipers in anticipation of the sz discs arrriving so i will wait and see who makes up the first set at a reasonable cost.
Pete, going back a few posts on calipers. I will posts pics on the hardest way to do a big break conversion with 15 inch rims(and only a select few 15nch rims). I think keeping the 315mm disc size realy made it difficult and using calipers that have 'lugs' make it impossible unless you can laser cut the pieces. Check out pics.
Mats what do you think of the shear on the bolts or the "meat' left on hub.
What's that, M10? I'd be worried... :?
Mats wrote:What's that, M10? I'd be worried... :?
Never! No problems here with m10..You will break your finger off in your ass before those m10 will shear! 8)
Geez Baz, you sure got some strange ways of doing R& D for brakes down your way. I can see by the time Kevin sorts his brakes out, he wont be able to sit down for a week... :D
Adds a whole new discovery channel to pickin' your nose too I might say.. :D
ALFA GTV6 GP
Twin calipers
Post by ALFA GTV6 GP »
Not my choice of braking options....
But has been used sucessfully but two Alfisti in Oz.
The additional weight would suck.
Alfa GTV6 3.0 (Silver)
Alfa GTV6 GP 3.0 (Red)
Alfa GTV6 GP (Concourse)
The problem is that there is no way that the friction between the bracket and the spindle can take that kind of torque on a small PCD like that. The bolt will take a lot of that load in shear.
That's not the proper way to design it, but I guess you don't care until the bolt snap. :wink:
A friend of mine has broken off the whole mount on a stock caliper once, that was "interesting" I bet. :shock:
the double caliper thing was original on the Giulietta Turbodelta... it uses very rare autodelta spindles and two calipers each side.
Don't know what they did with the mastercylinder to make it work properly.
I used Volvo 240 calipers, they are 4 pots. with the Giulietta 1.6 Spindles and the hubs and discs off a 75 TS this is a bolt-on job. only trouble was the double brake hose connection on the caliper, fixed it with a t-connector and two pieces of brake line.
Also used a mastercylinder of some kind of Peugeot/ Citroen van which is 25.4 mm. was 118 Euros but has the connectors on the wrong side( near the engine) so i had to lengthen the brakelines.
they are on this car;
Giulietta 1.6 1982
2.0 TS engine and gearbox
yellow Koni's and lowered.
castor-rodends and 28mm stabilizer
16" Azev A 205-45-16 rear 195-45-16 front
CSC rear silencer, no middle silencer.
This is my daily driver... 8)
Maurizio
Post by Maurizio »
@Kevin,
gut feeling says, M10 and the large brakes is not strong enough.
Ps comment on the V shaped bracket, I would like to see material between the bolts. Even if it is 2mm material, it helps a lot.
The autodelta units... I've seen several pictures of broken uprights from those days...
@Mats, your fast :lol:
wilwood disk (29.6mm) is wider then an SZ disk.
An standard caliper which utilizes 29.6 mm will be difficult.
Handbrake hydraulic shouldn't be that difficult for the people who need it to be road legal. This is on my long upgrade list for the TS 8)
+ Placing the calipers more into the wind. Here some pictures, stolen from a dutch transaxle forum, of a GTV6 GR.A preped by Imberti.
ps a nice detail, more room for the caliper (an "U" taken out of the dion).
Thanks for replies. Also thought of welding around the sides of bracket but then you also weeken areas around weld.
The double caliper method was used very succesfully on out gtv3.0l for racing in the eighties and also currently with one of the chaps in my class. It alows for least wheel modifications on the 15''. Only thing is you need thicker disc to dissipitate the extra heat(spaces in caliper).
Dawie has an origional autodelta double caliper hub still.
Jarle
Post by Jarle »
My budget brake solution for racecar: Wilwood superlites with GTA discs.
Budget brakes 002.jpg (208.36 KiB) Viewed 10784 times
Jarle,
Which GTA discs? The 305mm or 330mm ?
Also the way the caliper is mounted is there full pad to disc contact?
Jarle
Post by Jarle »
Its the 305 discs. They are heavy enough :). Full pad to disck contack..
Brakes_front 001.jpg (203.54 KiB) Viewed 10738 times
