Maurizio
Post by Maurizio »
drop spindles??
It's easy to do if you have access to the right equipment.
What did you use to weld them?
Daniel
Post by Daniel »
Welded with pre-heat, a MIG and post-heat as per AS1554.4. Part 4:Welding of High Strength Q&T steels
Then reinforced full length down each side with 6mm plate (also with pre & post heat) and smothed to remove all stress raisers.
Duk
Post by Duk »
Do you notice much of an improvement with the your drop spindle mods? Would you be interested in modifying a set for anyone else (road use)?
Love the custom stuff. Very innovative 8) .
grant
Post by grant »
Before he replies, I can vouch that they do make a difference, in a positive way :wink:
It's not earth shattering, but it was worth the effort for me (I just installed them, didn't make them!).
If you haven't seen this already, interesting discussion here:
http://www.alfabb.com/bb/forums/milano- ... ssion.html
Daniel, sorry to be a bother, but I need a reply on those adapters. I'm running a bit short on time now..
But if you can't do it, no hard feelings, I saw it as a favor anyways, you're a nice guy!
Duk
Post by Duk »
Cheers Grant, I did read just about all of that thread and a great 1 it was too.
Daniel
Post by Daniel »
Long weekend meant a little more progress!
Bumpers on, radiator in, oil cooler mounted.
Street use front bar setup, grill in
08-03-21 012.jpg (104.34 KiB) Viewed 9524 times
Front bar with lower lip for track use
08-03-21 007.jpg (101.72 KiB) Viewed 9526 times
Front bar with lower lip.
08-03-21 005.jpg (111.02 KiB) Viewed 9541 times
Big double pass aluminium radiator - should keep it cool.
08-03-21 002.jpg (129.37 KiB) Viewed 9515 times
Radiator fit up
Radiator fit up
08-03-21 001.jpg (118.65 KiB) Viewed 9514 times
Nice radiator. What does that front bumper come off. looks mean enough to intimidate the flying brick.
Rookie ROX
Post by Rookie ROX »
Looks like a slightly modified Evo front bar from the 75.
Looks good though!
ROCK ON
R~R
ALFA GTV6 GP
Post by ALFA GTV6 GP »
Looks like a Serpent body kit from Mark Papadopolous?
Alfa GTV6 3.0 (Silver)
Alfa GTV6 GP 3.0 (Red)
Alfa GTV6 GP (Concourse)
Rookie ROX wrote:Looks like a slightly modified Evo front bar from the 75.
Looks good though!
ROCK ON
R~R
Yeah, with the ribs in the openings cut away.
Daniel
Post by Daniel »
Yep, it is a modified 75 Evo replica - nice and light.
Also correct - it is a Serpent one from Mark Pap.
Kevin, I hope to do more than intimidate the flying brick. The plan is to give Mike one look at the front bar in his rear view, then only give him a diminishing view of the rear bar and tail pipes for the rest of the day :wink: (If I ever get it finished - right Mike :roll: )
Mezevenf
Post by Mezevenf »
Uh oh, very tough competition is quickly headed my way!
Can't wait to see it at the track/s :D
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
NightSpec
Dont count me out either. I am definately heading your way. Dont want to discuss it here on this thread but what are the regs for this category so i can see if its worth bringing two cars over.
Cheers
Rookie ROX
Oooh, sounds interesting! :lol:
Depends what you're looking at and who is running it. The Alfa Club has Road, Modified and Race categories (Race being the most common with more than 5 modifications), Sprints simply has Registered or Race (Unregistered), Super Sprints is similar to Sprints I believe, Top Gear is basically open Race - Then the categories are simply divided by engine size. If you get into CAMS events, then you come into categories that are specifically dictated by what's been done and probably more what you're used to.
ROCK ON
R~R
Thats great now I must check with your authorities how I can get the car in. Its fully road legal as you have seen as i would still like to drive it to tracks. I will move this to other.
