Hey there, I'm assembling a rebuilt clutch. I thought I had a clutch alignment tool from my fiat, but can't find it. Is a clutch alignment tool absolutley necessary? Is it specific to the Alfa V6 transaxles?
Bill in Maryland
clutch alignment tool?
Bill in MD
'88 Alfa Milano Verde x 2
'77 Fiat Spider
'77 Fiat Spider
Thanks Zamani.
What I ended up doing was putting the bolts through the pressure plate, then sliding the pressure plate, clutch, and flywheel on the tranny shaft. I pushed the assembly as far as I could in without the bolt heads hitting the tranny housing. Then one by one I tightened the bolts (only a turn or two at a time before rotating to the next bolt) through the upper clutch viewing hole. No I couldn't torque to spec but hopefully I'm close enough.
You could only assemble the clutch this way with the tranny out of the car imho. We'll see if it works out.
Bill in Maryland
Bill in Maryland
Bill in MD
'77 Fiat Spider
'77 Fiat Spider
