Baz,
Emailed you a couple of days ago. Need info asap on payments. Need part to get project going. Hope you keep extinguisher where you have my stuff....
One time the bonnet prop hit a power distribution block and nearly caused a fire (smoked the wire). Luckily I had time to disconnect the battery.
- Rookie ROX
Oh we had that happen to my Dad on one of our 75s - Prop jumped off onto battery, started smoking and power cut, he then jumped on the brakes and in a rush to stop gave the handbrake an almighty yank. Popped the hood and stopped it before a fire, but then discovered during the rush he'd pulled the handbrake so hard he managed to seize the cable and thus seize the brakes. He wasn't happy.Zamani wrote:Baz,
battery.
ROCK ON
R~R
Hey Z..checked it,thanks..
Today the second fan smoked itself...
and a misfire of note...another cap/rotor combo,wires,plugs , ANOTHER dizzy....same misfire..Measure the alternator output..14 Volts !! Great stuff !
Measure the # 15 terminal on the coil...7.65 V !! WTF ??..go under dash to fuse box , touch the 3 wire plug from the ignition switch..pretty hot junction right there !..Jury rig a relay into it and Viola !! 14 volts to the rest of the car !!
Now the fans can burn out in half the time !!
14 V on coil and my misfire is gone.....This little car is really running sweetly..
Until the next problem..I love Alfa`s !!
LOL`z ! Yea,stored in the flammables dept !! Small bucket of sand in case ...Zamani wrote:Baz,
Emailed you a couple of days ago. Need info asap on payments. Need part to get project going. Hope you keep extinguisher where you have my stuff....![]()
I thought it was time to post a pic of the storage Queen..!Now my daily driver.
- DSC00722.JPG (145.01 KiB) Viewed 7268 times
F,The fire was in the engine bay only..and was extinguished rather quick !
Anyhow,another set of wheels today..
- DSC00751.JPG (152.37 KiB) Viewed 7245 times
Greg, agree totally ! It really looks good.Im thinking of perhaps having the ex Kevin Campanatura`s that were widened powder coated in gloss black..Should also look pretty good.
- DSC00661.JPG (150.48 KiB) Viewed 7239 times
