hutchensgd
Physical location of the badge on hatchback "GTV6 2.5&q
Post by hutchensgd »
My car is nearly completed, and I was wondering if somebody could give me the dimensions from the right edge of the hachback as well as the location from the bottom edge.
Glenn
I can give you that, I have plenty of hatches here. However I need to know the year of your car and what the badge says, they vary a bit.
hutchensgd
Greg,
The item I am speaking of is a rectangular badge which has the following text: GTV6 2.5L
Thanks for your help.
Glenn
Glenn
hutchensgd
And the car is a 1984.
Glenn
hutchensgd
I received my new plate from ItalianCar parts, and it was perfect!
I did notice that my memory was mistaken, it does not have an "L" after the 2.5.
So all I need now is the dimensions to position it. HELP!!!
Glenn
tectoteam
Post by tectoteam »
hello
cant say it to you, the mines as gone years ago....
but ask it on a french forum, numberous owners.
http://www.purassanta.net/forum/posting ... wtopic&f=1
put in the subject: "position du sigle gtv62.5L a l'arriere du hayon"
and the content: 'bonjour, j'aimerais savoir quelles sont les position exactes du sigle 'gtv6 2.5L' a l'arriere du hayon, les dimensions entre le bord droit, haut et bas.
c'est pour le mettre exactement a l'endroit d'origine sur un vehicule concours.'
and i will translate you the answers.
bye
2 stroke addict
tectoteam
Post by tectoteam »
well in fact i did it.
waiting some days for a good answer.
also, there is more than this one.
the gtv62.5L is on the rigth but there is a 'alfaromeo' sign on the left.
2 stroke addict
Body Exterior
hutchensgd
If you get the correct badge, you don't need to obtain location dimensions as the badge is positioned on the rear hatch by two locator pins that go into holes that are made by the factory.
If the holes have been covered over by body filler, use a good torch and look inside the framework of the hatch on the right hand side and you will more than likely see the bit of filler that has come through the steel work. This will be your pin locator hole. Simply drill it out and you will have the exact factory location of where this badge needs to go.
hutchensgd
When I saw my car down to bare metal I saw no holes. In addition, the Alfa Romeo spare part which I purchased for this part had no pins in it either.
Glenn
gtv11636
Post by gtv11636 »
There are no holes in the rear hatch for this badge from factory as much as I know! It came glued on.
Sporttunergtv6
Post by Sporttunergtv6 »
please pardon my standard measurements but the badge is 11/16 of an inch from the right edge, it is 15/16 from the top edge, and 14/16 from the bottom... hope that helps
vittorio
Sporttunergtv6
i too have a 1984
I checked my spare hatches and none are 1984s. Sorry I couldn't help.
tectoteam
Post by tectoteam »
Sporttunergtv6 wrote:please pardon my standard measurements but the badge is 11/16 of an inch from the right edge, it is 15/16 from the top edge, and 14/16 from the bottom... hope that helps
vittorio
informations sounds the same.
12/16(19mm) form the rigth and 1 inch(25mm) from the top edge.
2 stroke addict
