Sorry to bother, I searched the old forum but with no luck. Can someone tell me the reading for the ohms out of the coil for QC reasons, also, which poles to check and which readings. Also, most importantly, how do I check the Ignition Module situated under the coil to see if it is still good. I have no spark out of the coil, I am trying to determine which part is bad. The car fired but after a six month parking period is now no longer firing. Yes, i have cleaned the connectors. Any help is much appreciated.Thanks for your time!
