Re: Fuel surge tank question
And the "out" pipe is pointing forward? Probably will never be an issue but still. :)
PietereQ
Post by PietereQ »
ar4me wrote: Maybe you have a separate feed pump?
Yes that's a must. I'll be installing lo press pump in the place of the original efi pump. As for the heat, I hope that thermal wrap should help a bit.
PietereQ
Post by PietereQ »
Me again. For the record I didn't make/design that tank :) The internal diameter of the outlet (to the efi pump) is 6mm whereas the pump inlet itself is 10mm. Should i bore that out or it will be ok?
thanks
PietereQ
Post by PietereQ »
Few pics of the low pressure pump (0,24bar 75l/h), still waiting for the new efi pump.
PietereQ
Post by PietereQ »
Well it's 12:30 AM here and ...
Honestly I didn't think she was going to start - i mean there ALWAYS has to be something, add to that a 164 alternator conversion - something really had to go wrong.
Ok so final checks, few looks at terminals on new pump, back into the car. First i cranked it for 20 sec to make sure that the surge tank and EFI pump was primed. Everything's connected I turn the key, one rev of the crank... second... third... cylinders one after another fire up and maintain stable idle! After 4 months!
runs smooth, revs excellent. I just need to hook up pressure gauge to monitor how it really works - so far 15 mins of running and everything is good.
Unfortunately theres a micro fissure on one of the welds on the surge tank - will need to fix that.
Heres the pic of still mock set up, but hell it works :D
Test drive next week, ill let you know how it performs in battle mode :twisted:
OzMidnight
Post by OzMidnight »
Are you going to insulate the swirl pot at some point?
Non Illigitimi Carborundum
PietereQ
Post by PietereQ »
Of course, and headers too.
PietereQ
Post by PietereQ »
Just thought I'll post pics of finished setup. Thermal shielding still to come... Test driven the setup and 100% satisfaction so far :D
Painted the tank jet-black, looks almost stock, huh? :D
I even made 'surge tank warning stickers' to avoid unnecesary questions during MOT :lol:
killaz
Post by killaz »
Nice work, PietereQ! The best of all is that you gave conclusion to this story. :)
PietereQ
Post by PietereQ »
Hey, guess my last post in this topic :lol: But I guess that now after the setup has finally beed tested in track conditons it was designed for, the story should be complete. So NO PROBLEMS setup worked 100% :) , finally I could put the power to the asphalt on exits of long/hard right corners, and say bye-bye to the quattro's behind me :mrgreen:
cheers,
Pete
