To my layman reasoning the 170/100/B12 (open length 17" closed length 11" stroke 6") shock should be the closest (best?) solution. And even with spring it should clear the upper control arm (though I'll be enlarging it anyway for more castor)
Here's the link to the catalogue:
http://www.gaz-shocks.co.uk/gazcatalogue.pdf (page 15
Ok so the questions:
1) Is the beforementioned shock the way to go or not? If no any other suggestions?
2) What springrates should I use? I want to run coilover torsion bar combo. My gtv6 is inevitably going to be a racecar, basically for the time being I want it to be road legal trackday car. (Have just few kms to the racetrack, so ride comfort is unimportant)
3) Seam welding. Absolutely necessary or only when I'll be running coilovers only?
4) I have read somewhere that you need to lower suspension (via torsion bars) before installing coilovers. Is there any fixed figure for that? Or trial and error?
Thanks in advance and waiting for your input guys
