GTV27
Re: Back again...
Post by GTV27 »
Those wheels are terrible - I'll do you a favour and buy them off you!
deja vu?
Jason
1983 GTV6 2.8 litre
Re: Back again...
Post by la_strega_nera »
Hah. well, yeah, that did happen last time I owned a set of Gold wheels on an alfa... :P
Pick up my freshly machined Adaptors tomorrow - $25 in machining and $15 worth of 6061 per adaptor - nice to have a mate who's got access to underutilised CNC Lathes and mill.
I've been knocked out with a virus that my g/f brought back from Hong Kong, so I hadn't finished the install of the vac line and the controller for the exhaust, but this afternoon I managed to pull apart the interior of the 164, tap into the coil trigger from the ECU, run the trigger wire and the vac line through to the boot... tomorrow morning is hooking up the controller and actuator - shouldn't take too long. No vids till I can con the missus into holding the camera.
1966 GTV
1982 Suzuki "Bathurst" Katana
GTV27
Re: Back again...
Post by GTV27 »
pics of girlf...wait...sorry, wrong forum.
actually finally put gold wheels to use last weekend - had to 'machine' the spigot size to fit on rear (must be 'big' 2.0 axles) but all turned out good - even have 1mm less offset than my other wheels, so it looks fully sic bro
anyway, pics of stupidly good looking gold wheels on 164 or ban!
Jason
1983 GTV6 2.8 litre
GTV27
Re: Back again...
Post by GTV27 »
proof of life
I wonder why it wears out rear tyres faster than fronts?
Jason
1983 GTV6 2.8 litre
Re: Back again...
boy, that driver must be REALLY heavy... :shock:
Re: Back again...
never heard of low-riders?
:wink:
hydraulics baby... 8)
:lol:
Re: Back again...
Hey Jason,
I think your 105 has ANT FOBIA.
You should train it not to recoil everytime it runs over one !!
Keep up the good work mate.. :D
xrad
Re: Back again...
Post by xrad »
f'n awesome pic!
Re: Back again...
So, it turns out that a 17x9" is really quite alot of wheel to try to stuff under a 164...
17x9, 25.5 offset (effective), 215/50 rubber (being turfed for 225/45s - it's what came on the wheels)
The rears need about a 5mm or so spacer to clear - the factory 3mm spacer just doesn't quite do it.
Looks the good from side on...
New wheels, from behind:
Stockos for comparison
Front the front... really fills those arches.
1966 GTV
GTV27
Re: Back again...
Post by GTV27 »
that looks tough - are you sure 225s will fit - 215/45 might be the go?
Jason
1983 GTV6 2.8 litre
Bruce
Re: Back again...
Post by Bruce »
.. a number of questions and a request.
Is it a 12v?
Are those rims really 9" (inch)?
I want to hear that exhaust!
Re: Back again...
Yep, 12v - 164QV - Quadrifolglio Verde, as opposed to 164Qv - Quatrovalvole.
Yeah, they're definitely 9" wide rims... 225s should still fit because the sidewalls will be straight up and down...
Will have exhaust vid eventually :)
1966 GTV
Re: Back again...
I have 235mm wide race rubber (usually 10-15mm wider then street rubber) on my 9" rims and when I stack the wheels the tyres doesn't even come close to touching each other.
Like this
Tight you say? You should se it with simulated roll... :lol:
Re: Back again...
Heh. You call that tight.
And yes. 9x18 fit the 164. Sorry for sucking photo quality. (and dirty finger)
Clearance FW 2.jpg (44.84 KiB) Viewed 7785 times
Q4 ATS.jpg (119.17 KiB) Viewed 7789 times
Q4 ATS Clearance.jpg (51.48 KiB) Viewed 7786 times
Re: Back again...
Fibreglass fenders doesn't count... :D
