Re: Mats Strandberg (SWE)
Hey Mats, are the ES30 discs still expensive? Last time I looked they were like 280 euro a pair or something.
Will be reading your blog, as I'm hoping to build a turbo Alfetta out of the 79' 2.0 I have at my house.
Very jealous of your 155 too. If we had 155's here I would be using that as a daily driver. I'm using a stock 164LS 24V right now and it eats gas at a rapid rate.
I got the ES30 discs used but unused, i.e. from a private seller that hadn't had them out of the box yet.
So the price wouldn't really tell you anything.
The 155 is parked in (on purpose) by the GTV, needs a cambelt service and that's not going to happen before the GTV is race ready.
I really miss driving it though, and now that the streets are cleared from all the sand/gravel they have used during the winter I really want to drive it.
Thanks about the blog, if all goes well there will be an update later this evening (Swedish time).
well, it's updated now anyway, the blog that is.
Some greasy engine pics, honing the liners to spec.
Shortblock - Check!
nice! How do you oil the head, outside line? or OE way?
How do I oil the head? What do you mean?
How the oil flows to the head? Why mess with something that works?
Nice rod bolts. Looks like "standard type"' headgasket set up coming. Whats thickness of headgasket . On my 16v 2.0 (Fiat -alfa) there are three types of thicknesses which my Alfa dealer did not even know. Gain huge on squish with all hard work but then lose with incorrect gasket.
Tnx.
I switched out the "ARP bolts" that came with the rods to real ARP 2000 bolts, the ones that came with the rods didn't even have a washer and the finish was dull.
Stock gasket yes, AFAIK there is only one thickness on the Alfa ones, Fiat gasket comes in a few as you say.
The aim was to have the head ready to mount on the block but the new gasket set was missing a (1) valve seal.
Wow, that is supercool to see this engine finally becoming a reality. I'dont recall you stating this, but what HP/Nm figures we'll be looking at?
Thanks, it's been a while. Sorry about that.
Realistically around 300Hp, hoping for more. Torque? Guess I'll have to limit it to under 400Nm to keep the box together. Not a big issue if you like to rev it, like me.
Mats,
Just interested - what's your life expectation for a motor like that (baring any problems) one race season? GV
20-Years-3-Motors-Later
More like 10 seasons. Everything is way oversized. I'm more worried about everything else, gearbox for instance.
After I wrote that I thought "Nah, it must be good for a few at least" Still, that's pretty impressive considering you're what, doubling the hp!
GV
