Z,I sent you pictures on what to do to use the long gtv6 cam in the 155 v6 motor.Its easy and very basic-no machining or anything....Zamani wrote:Jim,
Don't know about the specs, but they are 2mm shorter than all other V6 cams. So almost no performance cams for it. Need a used one to have it reprofiled.
You still got them? Follow the assy. procedure and they will work reliably,
- junglejustice
- drew_s`b`r
Bruce, assuming your advance curve and feulling is correct I personally would not go over6000 rpm unless I knew the engine was balanced properly and had relatviely new cam belts. My 1984 GTV3.0l used to rev smoothly up to 7000rpm with mild cams(Dawies group 1 spec) as the motor was balanced properly. Once went to 7500rpm when carb linkages jammed open, luckily no damage, just pants chainge.
I was in Julians 2.5 GTV(December in Oz) with standard rods, frighteningly wild cams with revved effortlessly to 8000rpm, which he has being doing every day for last few years and no problems then again the 2.5 does rev "free'r' than than the 3.0l.
I have heard the cam belts wont stay on above 8500rpm but I have seen our GTA motors rev to 8300rpm. Not sure why our drivers are taking it so high as the cams are still standard unless it to avoid a gear chainge. Barry, you could comment there.
Also had belts jump off on 12v 3.0l at 6000rpm due to worn belts (only 40000km old but oil leak accelerated wear)
Hope this gives some answers
