Re: Yankin' a Tank
Got a sheet of Dynamat in since the tank is out, and I've bean meaning to pull the Koni shocks and turn them to the softest setting... easy thing to do with the tank out! Thought I'd throw in a picture of the evap. system up above the tank - the lines are all hard as a rock, and I'll replace them all once Greg G's kit arrives. GV
- evap.jpg (140.92 KiB) Viewed 8763 times
20-Years-3-Motors-Later
Re: Yankin' a Tank
I like dynamat. Did my other car with it, all the under carpet and flat panels. Not covered completely, but enough to deaden the panel's sound. Sticks well and worked great. Some say it weighs too much, but I used about 16 sq feet and this probably weighs in around ~15 lbs. Just a guess as it has been some time.
Re: Yankin' a Tank
I just realised that I am either going to have to add a second fuel filter somewhere before the fuel pump... don't know where exactly. Or swap the fuel pump and filter around since it won't be a good idea to go to the pump without a filter first...
Thought I was making things simpler by getting rid of the intake filter now it seems like it is more complicated
Re: Yankin' a Tank
No filter before the pump except the sock on the in-tank snout, you can get ugly problems with cavitation in the pump.
Re: Yankin' a Tank
So... if I am now rid of the in-tank filter is my pump going to be short lived (Though the tank has now been cleaned and coated)Mats wrote:No filter before the pump except the sock on the in-tank snout, you can get ugly problems with cavitation in the pump.
GV
Re: Yankin' a Tank
I have run into this problem, sometimes the in tank sock/screen filter is beyond repair and you have to remove it. In these cases I suggest a regular low pressure filter placed in the fuel line between the tank's outlet and the pump. It will work fine, there won't be any problem. Of course you have to locate it where it won't get caught on any moving parts, or heated up too much by the brakes, but that's not really a problem unless you are doing something weird with your fuel line.
My Grey GTV6 has this setup, and it worked fine.
Greg Gordon,
www.hiperformancestore.com
www.okinjectors.com
Greg Gordon,
www.okinjectors.com
Re: Yankin' a Tank
Thanks for the advice Mats and Greg
Have the fuel lines in hand so I hope to have it fueled up and revving down the road this weekend. GV
Re: Yankin' a Tank
So, drop off the tank on Monday, tell them the bung needs to be mounted 1/4' lower... no make that 1/2" and hopefully I'll get it back by the end of the stupid week. GV
Re: Yankin' a Tank
On a good note - Greg G's Above Tank Evap. Line Kit went on without a hitch
it was really nice to just pull the pieces out and replace them as labeled and not have to think about it, measure the different I.D. hoses that would be needed or make 10 trips to the auto parts store. GV
Re: Yankin' a Tank
Sorry to hear that...I had same issue
from my earlier post:
"Forget all the alfa tank fittings/bungs. Have shop put in a whole new bung put in place (forget the intank filter) that will work with standard fuel fittings.
make sure it is low profile fitting(bung) ,so that you can get the tank back in without body work... "
Re: Yankin' a Tank
Yeah, when I picked it up it looked marginal and of course it was by 1/8"... good news is they'll have it back to me tomorrow. GV
Re: Yankin' a Tank
well you will still have time to enjoy the summer...
Re: Yankin' a Tank
Hi, sorry, we did not read about your dramas earlier. Last weekend we pulled the tank out of our GTV6, with the filter bung still in place and the sender unit still in the top. We did read your postings very earlier on and noted in the back of our mind your problems, but forgot to update on our progress.
Our solution (may help someone esle) is to wriggle out the LHS of the tank, thus skewing it sideways, then tilting up the LHS, this allows the bungs to rise up over the holes in the boot floor and then the tank pulls out. Yes you do stratch it a little. But it definately comes out.
Also, with no in tank filter, you will need to drain you tank regularly and flush, as there is no filter now before the fuel pump. Our pump has just been thrown away as it had rotten fuel in it for too long and had clogged with sludge, despite the in tank filter.
thanks and hope to hear your on the road soon.
Peter
Peter
Re: Yankin' a Tank
Thanks guys. I've owned this gtv6 for 21 years and even with periodic fuel additives over its life there was still rust in the tank. No sludge, and not a ton of rust, but enough rust to cause running problems. These cars are now all pushing 25 years old, flushing/pulling and cleaning the tank is becoming a must for ownership now i think. GV
Re: Yankin' a Tank
The 90-degree Earls fitting that threaded into the tank lined up just right. I had the shop weld the bung so that the when the Earls fitting was screwed in just hand tight it point towards the front of the tank - once in place I was able to wrench it around for two full revolutions... nice and tight
Was going to move on to some new front torsion bars, but since this project used up some time I'm going to wait until the end of Summer. GV
- Tank fittings
- trunk2.jpg (208.56 KiB) Viewed 8512 times
- Done at last!
- trunk.jpg (208.53 KiB) Viewed 8513 times
- Two fuel filters
- trunk3.jpg (226.36 KiB) Viewed 8513 times
